Between the IF Gain control and TX RF meter setting - they should both be pretty close to mid point - but not all meters work like they should - some seem tighter in RX S-meter than say the older OEM one which drifts like a dinghy behind a Caribbean cruise ship - just lollygags along not really showing anything but "working".
IF you like the new meters "stiffer" results - how is the receive?
But if the noise floor seems too quiet and IF gain tends to overemphasis on the noise level - then AGC may be part of this problem. That is a simple fix or change of 1 part and observe the results - if you don't like it - revert back and understand you might not have much you can change...
The AGC "Resistor" that I'm referring to is R26 - schematically it's a 22K - RED - RED - ORANGE
This controls how much energy the Receiver sends back to the front of the section to control and maintain some leveling system of signal to Noise ratio when a receiver is wide open to fully immersed, for signal. level.
To many this part doesn't do much for them because IF gain can handle most of the conditions. But the quality of signal and the dynamics some signals will have - they get lost in the IF gain control being too limiting of range.
So there are the following components, resistor R26 (22K) - the AGC Cap C37 4.7uF (you can go up to 22uF or as low as 2.2uF) or the 455kHz IF Cap - C22 a Tantalum of 10uF at 6.3V rating - so the issue is not yet complete when it comes to a true recapping - you have to look back and realize the values used (back then) were for a specific outcome due to the tolerances the parts they used in the assembly of this thing - was one value - but you just put in similar parts but of different reaction in capacitance characteristics you didn't expect - it's not anyone's or anything's fault. Only understand, they act this way because of the internal structure of the part is different and the circuit was originally designed to work one way with this part - but now acts differently.
This is normal.
I'm asking because if...
- seem a little too quiet?
- perhaps the audio more comrpessed than you remembered.
What happened to what it sounded like before all this work was done?
It could be from the recapping and the tolerances the parts list to what you used may have been exact - but the response is different now. Because of the changes to the Basic Capacitor design during the time this thing had its last oil change.
So there are some "tweaks" you can do to it in its' stock form - being mostly the IF gain control and maybe a retune of a coil or two - - the only other way to adjust the "Meter seems Low" issue is to change some parts that will affect the receive performance - some might like it, others might hate it - so if you like the noise floor it has now, well, just live with it.- seem a little too quiet?
This is normal.
