President Ronald swing mod
Might have to give this a try on mine... well, maybe part of it.
Does this affect deviation on FM at all?
Install 1n914 or 1n4148 diode, cathode to the center leg of AM regulator trace as pictured. Make sure you don't accidentally short the leads on the cap your soldering the anode end of the diode to.
Enter the service menu to set your power levelsView attachment 66650View attachment 66651
That will be a hack job if you don't put the right value resistor in series with the diode. You will need a scope to properly set this mod up. Different values for different power settings and proper mic gain setting or it will be a splatter box.
