Running a President McKinney mobile, Midland HF747 amp, which is putting out between 90 and 110 Watts, 9' whip dead center the roof, 9' RG8X coax radio- to-amp, and 18' RG8X amp-to-antenna. Cheers!How much power are you running? I usually run a Uniden 980 or old President Grant with a RM 203 behind it and have no problem with my stereo amps or speakers. On weak stations it can wash out my reception. The only problem I have is my seat belt light will light up and eventually start dinging if I talk for a while. This only happens when I use my Wilson mag mount. I have no problems when I run a whip mounted to my toolbox.
