T
TalkingTall
Guest
I have a Dosy Test Center model TC-4001
The problem Im having with is the needle will not go past the 4 on the meter in any mode.
I cant set the swr or the modulation because of this problem.
To get a peak reading on the watts for my radio, I have to set it on the 200 watt setting.
I can't even check the wattage on my 2x4 on the 2000 watt reading because the needle wont go past 400 watts.
Anybody ever run accross the same prolem or maybe have a suggestion on what I can do?
I called Dosy and they told me if I sent it to them it would probably cost about $40.00 to repair and return.
It would cost me $10.00 to ship it there, and I really dont think a Dosy is worth sinking $50.00 into.
Thanks ahead of time for any suggestions you guys might have...TT
