Click here to find out how to win free radios from Retevis!
Programming software for Motorola GM300 (download here)
Attached is the software for programming and aligning the Motorola GM300 radios. This is DOS software and you need a real serial port. A USB-Serial adapter will not work.
just for those interested, if you dig into OTVDM or VINEVDM (i had better luck with otvdm), you can enable 16 bit applications to run on a 64bit system. I was running both the old and new CPS for a m1225 on windows 7 using otvdm using a usb serial adapter. Been so long that I can hardly remember doing it, but I know it works.
