You may want to look into a QFH(I think that is what they're called) antenna, a quadrafilar helix for RX. A guy on radioreference built one and used it to RX from one of the NOAA sats with a scanner and the images were great.
Have you tried your current antenna at a 45 angle? W6GMT's qrz page says he uses a pair of elk antennas at 30? degrees, how I don't know, maybe 1 horizontal and 1 vertical to compensate for the satellite tumbling through space(as Moleculos video stated).
Have you tried other sats with your budget setup? For some reason, I think that AO-51 has circular polarity antennas, AMSAT.ORG possibly?
Congrats on getting the setup to work,any setup has its pros/cons, eve K8YSE setup hits a 1 minute snag when it hits the south stop and has to turn all the way around
