Nomad is correct, it is money and if that is what you want and you got it to burn, its yours to burn.
345 is correct that you over build, and make dam sure you got all your ducks in a row and it will last.
But you got to cover all the bases.
The statement that 100 watts is all you need I disagree with.
Yes depending on what band, and depending on band conditions you can make lots of contacts.
But other times 100 watts don't cut the mustard.
If 100 watts was all you ever needed, all the company's that build legit HF amps would not be around.
My Humble Opinion is that for a every day mobile some were between 300 to 400 watts is about all I want to deal with anymore.
