I have worked the west coast using a Imax 2k which has been used for 10m only, still studying for my general, hoping to take my test in July, thats the earliest date I can take it here...
But thing is, I hear guys talking about using a dipole, and how I should do this and that, thing is I have about 72ft long span I have to hang a dipole in.....but to get any height or to reach the tree line, I'd have to cross the power lines, because if I was to go under them to get to the trees, a dipole would be about 20ft off the ground, then go up the hill to the tree line....this is a no, no if I was to do this ?...
The 72ft I mentioned, is what space I'd have from my drive way to the edge of the hill side, before you get to the power lines and the trees is above the PL's....I forget the lengths, but to work the 40-80m band I'd need a longer wire than 72ft span...I no I have to pass my general first, but just curious on this.....is there a right way doing this in my situation, if so what would you do ?...
