We might want to move this post to the Installations section.......Anyways Logan, I have a 85 GMC half ton myself....I wasn't to fond of drilling a hole on my roof top of vehicle.....I used a Wilson 1000 magmount, slapped it on center of roof top........At the bottom of magmount, I ran my coax down the right side of rear window, you can carefully roll it behind your weather stripping to hide it.......Once I reached the bottom right side of window. I ran coax down between the bed and cab, I drilled a 1/2 " hole from behind the seat...unscrew the connector at the end of coax from the Wilson or else you cant get it to go through the hole that was drilled........Then I ran coax underneath the plastic strips running on floorboard right where the door shuts....... (You can run coax on either side of vehicle right or left)........Then undearneath floor carpeting to you desired location.....I don't know how much juice you want to run, but possibly a Wilson 5000 if your gonna kick it up a notch......This is what I'm using, maybe you'll get some good ideas from some of the other forum members..........Good luck bud.......Now we just need some conditions........73's
