And another perfectly working radio was sent to heaven due to the dumbass golden screwdriver brigade trying to make them run power they were never designed to with an increase that's barely going to get an extra S point to the other end, assuming of course that the extra power is actually going out on the channel you're transmitting on, not spread over several either side a well as 81Mhz..
If you want more power then buy a linear amp. The best you'll ever do without one is double the power, an extra S point to the other station but running the stock PAs to screaming point and leading to their premature death, that's assuming they don't die in your attempts to wring every last milliwatt from them.
