On 160 i use a 77 feet vertical ( former inverted L of 136 feet) good for ground wave up to 80 miles, though sometimes even further with mixed propagation even midday. ( to the UK)
Low angle for dx till now USA canada, South America EU MIddle east Africa Japan, China Australia and some more in SSB.
For 10, Imax 2K daily direct line of sight 20 to 30 miles to other fixed station ( minimal S9) running 50 to 100 watts SSB.
rest of the world in other propagations, SSB/Digital.
Real ground wave quickly goes down after 3 MHz, the same 77 feet vertical is used with autotuner ( MFJ998) on 80/40/20/17.
There on 80 minimal ground wave not good for local but good for longer distances, for local the OCF FD-4 is used , 40 the same where the vertical has almost non existent ground wave left.
20 and above just low angle work.
Even on 10 some of your RF will bend with the radius of the earth making longer distances possible as to the horizon.
Even happens on 2 meter.
That Imax is at 12 meters up from the ground top at 19 meter, or close to 60 feet above ground above my 3000 feet radial field for 160 meter vertical on salty sea clay.
That same salty sea clay stretches out 20 miles up to the sea.
I bet that helps in any way.
Just my observations after 45 years hamming.
