https://www.ebay.com/itm/254375574086
Something like this. But I would need for it to handle 23 amps
Believe it. Why would you doubt the manufacturer? These rigs aren't some piece of class C CB crap with false ratings. My FT-857D requires 22 amps to run as do pretty much all 100 watt class amateur radios. Running that rig at QRP levels is extremely inefficient and likely still requires at least 10-12 amps even at QRP output levels. True QRP designed rigs are MUCH more efficient at low power levels than simply dialing back the power on a 100 watt rig.
Hams don't use battery boosters as a general rule. There are far better options than a band aid. Get rid of that 100 foot length of wire to begin with. It's killing you. That's 200 feet of wire taking both + and - into account. 10 gauge has a resistance of about 1 ohm per 1000 feet so that makes 0.2 ohms for all 200 feet of wire. At 10 amps that is 2.0 volts lost so now you are down to only 10.9 volts on your fully charged batteries. WAAAAY below spec.
Only way to know for sure is to measure it, unless the manufacturer tells you the answer.
100w / 13v is 7.7 amps. Have to factor in efficiency...which is almost certainly higher at full output than it is at QRP levels. 50 % efficiency would double the ampere draw...15 and change.
I suspect it’s not 23 amps with a carrier, however. Your radio shouldn’t do a 100w carrier. I’d imagine that 23 amps is probably max ampere draw on AM mode.
I assure you that my ICOM 7600, ICOM 746,& ICOM 910H will all dead key 100 watts or more and do 100 watts on Peaks on SSB as well as designed.All of them pull over 20 amps on peaks as well.I have never owned any 100 watt HF Radio that did not do 100 watts on FM or SSB since 1994.I like using FM Repeaters across the country when the 10 meter and 6 meter bands are open because it’s just different from the same bunch that you find on SSB & AM.The AM carrier is usually anywhere from 25 to 40 watts on AM on most HF radios.
SIX-SHOOTER
injection voltage is 32V to get 12.8v at the other end.
I don’t doubt you at all...but the AM carrier is what I was referring to. I think most 100w rigs do not have a carrier that high?
I’m ok being wrong though, as is definitely applicable from time to time.![]()
As I stated in my last post,Most all HF Radios have an AM Carrier from between 25 to 45 watts.I don't know of ANY that have more than that.Most 25 watts Carrier & even the 200 watt radios such as the ICOM 7800,7810,Kenwood 990 & Yaesu FT-5000 don't have a 100 watt carrier on AM.
SIX-SHOOTER
