That's the way it seemed. I think they might have damaged in more ways and UNIDEN refused to take it back. Look out for amazon sellers. If it seems to good to be true, it is.So instead of reverting it back to stock, they just repackaged it and sold it...?
SIGH...
I might have to buy one of those to replace the 980.Nevermind just grabbed a Anytone 5555 v6 for $165 new in box of EB.. seller just listed it, won't fit in his car..
The only real way you would know, is to buy it and open it up and look for L9 and what has been silkscreened onto the PLL chip.
If L9 has a 100 ohm resistor - you have a true Diamond in the Rough - meaning it can work well with a little TLC, or it can wind up burning down the table - reverting back to whence it came - a lump of coal...
If L9 is just that - L 9 nothing else and it (PLL) says RCI - 8719 -heed the date code. Anything with 06 or later was under the RCI blanket of radios and they sourced their own parts - like what they do now.
So if todays quality level is acceptable - that's fine, but you'll pay for issues if they crop up. (Silver solder is one due to the Pb - Free compliance stuff)
Earlier ones, you have to go thru Dynascan as for the parts are more than likely from them, than RCI.
If you are going to use it on SSB (that will work out fine IMO); then also make sure that the AM Limiter is in there. Seen too many of them removed in these radios. Otherwise, it will sound like crap on SSB. Contrary to the belief of some, removing the limiter doesn't affect SSB. Not what I'd seen time and time again. Put it back in for best results.Robb,
That's good to hear. I only use sideband so stability does interest me. So this one may find itself as a back up rig.
My plans are to re-cap it, remove the "talkback" mod and blue meter LED and shelve it like the other 10 or 15 sitting around here. If there is a need to swap the resistor as Andy mentioned I will certainly do that as well. This one has had the final replaced at some point (but replaced with a Mitsubishi 1969) and TR28 has been replaced. Other than that, it's all stock. Kind of amazed since it is 23 years old this month.
For what I have in it and what I will have in it when it is done, I can't complain. Besides it gives me something to do and learn from.
73's
David
