RCI-29 purchase update: Beware!!!
The "Truck Stop Tunes" actually takes gain away from the radio, in exchange for watt's. The watts are useless without the gain.
Think of gain of watts the same as you would think of amps of AC volts.
What good is 120v AC with 0 (zero) amps?
What good is the voltage if no amps are present?
Stick two fingers in an 120v AC outlet that has 0 amps, you'll get a shock, but it won't kill you.
Now stick two fingers in that same 120v AC outlet and apply 3 amps to that 120v, it'll knock you across the room and could kill you.
Now, with that being stated, what good is 50w without the gain to back it up?
The gain is the goal when tuning a radio, we've learned a lot throughout the years. The gain comes from the sensitivity, the sensitivity comes from the alignment.
Yes, hacking, jacking, molesting these radios, and removing the limiters will result in higher watt meter readings, but at the cost of the gain.
The synthesizer oscillators, carrier oscillators, VCO voltage and buffer(s) all play a major role in the gain of a radio. No special "secret" tricks to it.
Just my 2 cents on the situation with truck stop tunes.
That is very interesting. I am fascinated by RF power and always thought that the gain produced the watts. But like you said, if there is no current, then nothing is happening. I am slowly getting equipment together to be able to do my own alignments, and learning as I go. I always enjoy your posts, and like to follow along to see what the fix is.
Thanks,
Chris
boy Hawkeye you've got me here.
I can't figure out what you're trying to say.
especially the part about the AC outlet.
is there any way you can word that differently to help me understand?
you do understand that amps are pulled by the load and not pushed by the supply right?
and the "what good is 50 watts without the gain to back it up"?
im not sure what you're trying to state here.
i mean no offence, i just really don't understand.
Watts= total energy. Volts = electrical pressure. Amps = electrical volume or flow. I'm not going to derail this thread so I won't reply from here forward to this thread. But, I will be happy to discuss this with you in another thread if you start one.
The problem is the Ranger RT-5 finals. Biasing a switch mode MOSFET into the linear region for clean SSB use is somewhat tricky. They are instable enough to be very dependent on temperature compensation in the bias circuit. Sometimes the diode or thermistor used to sense the temperature, is not even properly mounted to the heat sink or transistor.
That eliminates the chances of ever getting one fixed bias level, to maintain the proper bias, when you're transmitting for different lengths of time. Bias in the first 10 seconds of transmission may be correct. 20 seconds later, it could be double and still rising, without effective thermal tracking.
I'd also be reluctant to give the same shop, 3 times to get it right. That's when you start demanding a refund. The short time it takes to burn up, strongly suggests thermal runaway on the RT-5 finals. What needs to be identified, is if drain / source current to the RT-5's is rising as the radio is keyed longer.
If it is, bias alignment is really just an unreliable Band-Aid cover-up. This places your technician in the awkward position of having to decide to keep the bias low enough so that it never creeps up into thermal runaway, sacrificing added distortion and reduced output. Setting it so the radio sounds clean, means long transmissions, especially with carrier, will enter a condition of destructive thermal runaway.
I've seen this problem before when I experimented with $1.27 TO-247 MOSFETS in a 170 volt line powered linear. The best thermal tracking could not respond fast enough to the temperature changes occurring inside the transistor die.
If thermal tracking is intact on the RT-5 finals for the RCI 69, this problem can still be corrected. When the electronic approach fails, try the hardware approach. By using as little as a 2 inch square, 1/4 inch thick copper spreader under the RT-5s, stubborn thermal runaway can be tamed.
Just me explaining more of what I was getting at.
Wattage is a unit of power, representing the rate at which energy is transferred or converted.
Gain is a measure of how much an amplifier or a device amplifies or boosts the input signal.
Many things in life have relationships to each other.
More examples:
What good is 700hp from an engine, if you don't have the torque to get that 700hp to the rear wheels? Would you get any use out of a 700hp engine without the torque?
What good is 13.8vdc on a CB radio without the amps to back up that 13.8vdc? Would a CB radio doing 150w work properly on a 13.8vdc source that has only 5 amps?
What good is 240vac if you don't have the amps to back it up? Would a central heat and air unit running off of 240vac work properly without the amps to back up that 240vac?
Same with CB radio, everything pertaining to HF/CB is related to gain. Again, what good is a truck stop 50w simple peak and tune without the gain to back up that 50w (ghost watts)?
Every radio I have went through, that had previously been to CB truck stop shops, now drive amps harder (some even getting more output than before on their amps) and reach farther. And that's with all the limiters intact with nothing more than a complete alignment, main focus being on the Buffer(s).
I had one guy call me a couple days after he got his 2547 back from me several months ago. He asked me "Hawkeye, how in the hell did you do this?". After he explained that the radio was doing 19w when he sent it to me, and now doing only 16w, he's getting 250w more out of his amp and the whole time when he is speaking, the power needle never drops like before, "How'd you do that Hawkeye with less output from the radio but more output from the amp?". I explained it exactly as I explained it above, what good is 19w without the gain to back it up. He's now a die hard Hawkeye client, lol... Bout every radio I go through ends up stronger than before, regardless of ending output results on a meter.
More examples:
Ok thank you i think i see what you mean now.
I would probably word it a bit differently, but the effect on performance is the same.
This is how i would explain it to that customer.
Your 2547 was showing 19 watts PEP on the wattmeter, but wattmeters are dumb and dont care what frequency those watts are on.
When the truckstop clipped that limiter, they did indeed make the radio do 19 watts, but not all of those watts were on the channel you meant to transmit on.
some of those watts were at 54mhz and above and were doing you no good as far as getting out further. all they are doing is heating up the radio and most likely causing an SWR mismatch with the input of any amplifier you connect.
when a real alignment was done on the radio and the limiter was replaced, the radio does 16 watts PEP but all of those watts are on the channel you are on so you're actually driving your amplifier correctly and getting the benefit of every last watt the radio can cleanly produce.
one great way to show those who disagree is to place a low pass filter between the radio and the wattmeter and watch the watts decrease.
thanks Hawkeye for taking the time to help me understand your point.
Well said loosecannon ! That is a very good explanation !
RCI 29 base update, AGAIN!!!
Both guys got their radios back a couple months ago. Been waiting to see if anything pops up before giving another update:
One of the RCI 29's are still working fine after sending it back to RCI for new mosfets. This was the one that talked the radio to death, lol... I think he's realized he can't get long winded (staying on the key for 20 to 30 minutes continuously) on newer mosfets.
The other RCI 29 (the one that never transmitted straight out the box), transmitted for a little while, then stopped Transmitting again, no AM or SSB transmit at all. My guess, the factory still jacked that bias up. This guy doesn't talk much and he never holds on the key longer than a few minutes. I told him I would replace the mosfets if he buys them, but I will be setting the bias to what I always set mosfets for. Haven't had a complaint of a blown mosfet or bad transmit yet by setting all mosfets to the same setting.
My advice, wait til the version 2 of this radio comes out. There are still a lot of issues popping up on these rigs.
They both bought their RCI 29s straight from Ranger, then sent them to Superior CB for the work, then sent them back to ranger for the repairs but ranger sent them back to Superior CB for the repairs. So, it's either Ranger with bad batches or the Superior CB work. No one else has been in them. Especially not me, cause those radios are surface mount, which I don't touch cause I can't see the parts
I'll agree but disagree at the same time.
It really depends on where you bought it and who set it up. That's just the way it's always been with anything made by Ranger. It isn't only the stuff of today.
Go back some years and we saw the 98vhp's, 4300-300"s all would fail when done up by any golden screwdriver.
Buy a Ranger from a real tech, not a hack shop, a real alignment and they will work. That's just the way it is with ranger, it's nothing new. Only thing that's different here are the radios.
Buy new Cobra 29 and call it good.
  • Haha
Reactions: Hawkeye351 and TM86
Hello,
I had somebody bring in an RCI 29 that has a burnt MOSFET in the back near the SWR board it's marked q81, replaced it and it burned up again, Don't seem to find any shorted components around it. Also it doesn't turn on at all with AC power but when you power it up on the DC side that transistor automatically pulls almost 30 amps. Can't seem to find any schematics or what this part does, any ideas would be appreciated!
To draw 30A and not notice anything else smoking, it would need to be directly connected to the power supply rail. Crowbar? Class D audio amp?
Now that thermal imaging camera attachments for smart phones can be had for half the price of that radio, it is something every shop should invest in. Connect it to a constant current supply, dial it back to 1 amp, them see what else warms up.
    535A has left the room.
  • @ AmericanEagle575:
