Hello it's me again, again lol. A friend just brought me an rci 2970 that has very low if any modulation on am (screaming in mic) and almost nothing out, barely moving mod meter and wiggling watt meter. Radios rf power turns wattage up and down and has modulation on fm, lsb, and usb. Adjust from 12 watts to around 75 dead key.
I upgraded all audio amps and regulator 2sb827 and a1869. Before and after testing voltages on the center legs I get 2.9 volts, both 7808's read the voltage they're supposed to also on pin 9 of the audio ic ta7222ap I get 2.9 volts instead of the 6 or 7 vdc that's supposed to be there. I replaced the ta7222ap and same problem 2.9v on pin 9. The collectors of the driver and final is also 2.9 volts. There has to be a problem somewhere in the circuit providing voltage, does anyone have diagrams of these circuits and voltage checks for them? And where does this voltage start from the regulator or audio amps? I'm kinda stuck on which part of the circuit I should go to from here.
Also want to add I replaced both mic amps near the front of the radio by the mic plug on radio PC board. 2x2sb1240's I've had this problem before where low to no modulation was caused by them. Thanks ahead for any and all the help, much appreciated
