Rci 2970 low voltage on pin 9 of ta7222ap
I'll check the cap and Q57 and see what's what and get back with you, thanks handy Andy.
FM is out no carrier and no sound transmitted. Seems only sideband upper and lower is the only tx I'm getting. Am transmits but very low modulation dead heading at around 40% and swings no farther. Wattage in swing is only 5 watts from wherever the carriers set on am also.
Reactions: Handy Andy
Thank you Andy, I went ahead and just swapped out both Q56 and Q57 with new c945's I'm looking for a replacement that's high enough voltage for R240 now. I have some here in the pile somewhere.
The TX audio does not go through the TA7222 audio amplifier. Not for TX. The TA7222 has a mute circuit that "disables" it in TX. Pin 5 and 4 are hard clamped by a diode and 10k resistor, I am at work now, so I can't pull up schematics.
It's fine NZ8N I got time to play around with this one some. I appreciate the help alot though, I have things to get done also. I'll be back around this evening to try some more tinkering with it.
Reactions: NZ8N and Handy Andy
Also, check the AMC/ALC circuit, it might be hard clamping too. There might be just enough audio to bleed through to tickle the side band modes, but not enough to tickle the carrier modes.
I have this exact same 2970 first gen model, have had a lot of them in the past, so I am very familiar with the chassis.
Sorry y'all just got time to play around some. I just desoldered tr32 and modulation went from 40% before to around 82% after, but still with d104 and mic gain wide open not very good.
