Remove D67 from the board. Or install a switch to bypass it so you can turn it on and off.
I'm going to try this is my 2995DX and see how it goes. Mine is a current late model. Will post back how it does.
Also have an older 2970 non-DX that the sites say do the same deal to D78 but I have looked and looked and I can't find D78 on the board anywhere. Has anyone done this and can tell me exactly where to look for it? I've even seen it on the schematic but can't spot it on the board.
It should be just in front of T1 on 2950 board.
Thanks but it's not a 2950
Right, it's a 2970 non DX. It should still have an EPT295013Z main board, it just has a single final and the amplifier section attached to the bottom.
Did anyone ever locate d67 on the newer dx boards to add talk back?Gotcha Warbird, didn't realize you were responding to the 2nd item. Next time I'm in the 2970 I'll look there for D78.
Thank you
Thread is 12 years old lolDid anyone ever locate d67 on the newer dx boards to add talk back?
