Hi all, I picked up an HTX-100 that was stock, I carefully did the all band mod and I am pretty handy. I cut the trace properly ( and did not cut anything else) and then soldered the 10K resistor to the appropriate pin with 5VDC. After all this I find it still only covers 28-30mhz, can not get below. Again, I checked the trace cut and where there was continuity before between pics 28/29 on the IC going to the surface mount resistor there is no more continuity which shows the trace was cut. The 10K resistor was properly soldered to the correct pin from pins 28/29 on the IC. Radio still works perfectly but won't go below 28mhz. Any help out there good people? Thanks, Adam
