Realistic TRC-427 Audio Mod 'GoldFinger'
"People can’t hear sounds < 20 Hz and > 10,000 Hz very well.
Off subject....
Can't hear under 20Hz well but you can sure feel it! Man when I was into car audio, doing the shows and d.b. drives, it's incredible what 30k watts released through a wall of 15" subwoofers can do to a man.... shake your eyeballs and reorganize your guts!
After being off the radio since the 70s decided to get back Into it again. I bided on a TRC 427 the bid was -6 dollars I'd forgot about bidding on it and won it for 6 dollars and fifty cents. I had already gotten my Antron 99 the month before. Long story short hooked the 427 up to my A 99 and ask for a radio check and a man with the handle shotgun came back this man was 33 miles away. Can't beat theses radios don't know if its been peacked and tuned or if its stock. Can I run a A35 power deluxe without hurting the radio and what needs to be done in order for this radio to handle if. Thznks
