Receiver Section Questions
Didn't really want the whip to DENT your tail feathers...
In Proper Care and Feeding of 102" whips - the use of Tennis Balls is optional and also provides a method of protection for both the user and the newborn smaller whips that usually begin to show.
This helps the expectant mom-to-be raise the whips in a less jostling environment that aids in their development from short stubby coils onto long slender whips that are more effective when skip is rolling.
We wish you the best for a painless gestation and delivery of your new antenna.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
