If you have the room and don't want to go real high as far as base of the antenna, the sirio vector 4K is a great antenna. I've one up at 26ft to the base and it talks locally out to about 50-70 miles on SSB with about 50 watts of power. I have used less power and talked as far, but I will be honest and say what I run it at most of the time, which is 50w or less, depending on low local they are I can use as low as power as my Icom 746 will go on SSB, which is 5 watts. And those are the ones that are around 5-10 miles. These are under normal operating conditions for me, and just my experience with the antenna. It also works great on DX as well.
And I will end it with saying it has seen its share of bad weather and high winds of over 40mph at times and sustained 15-20mph winds. Antenna still stands as when I first installed it. There are better antennas as far as quality of materials and thickness of aluminum used, but they are almost 3 times what the vector 4K costs. Weather proof the connector at the antenna and it shouldn't give you any issues. Like I said, we have had some bad weather lately and it's been windy and rainy. Antenna is still working as it should. Again, like I said there are better antennas out there as far as quality of some of the materials used, but for the price, they are a good vertical antenna that really does work well for local comms. JMHO. And I am no antenna expert, I am just speaking on my own experience so don't flame me fellas LOL!!
