The 980 mic is fairly decent for a stock mic. If you don't need the noise cancelling feature, you can increase the clarity and audio quite easily. Open up the mic and remove the black rubber disc that sits in front of the mic element. I was quite surprised when I did it to mine.So found out my culprit I think. This 980SSB is interesting the more and more you poke at it. The microphone I was using seemed to be not acting nice with the ALC and with lower power on the radio as a whole. I think the noise cancelling effects of the Ranger SRA-198 were dipping the modulation down far enough to give false readings to the ALC and the radio was just reducing power to stay in "Optimal Levels" for clarity.
SO! Stock mic works fine and consistent, and I guess the SRA-198 is just too aggressive on NC for the 980... which means the SRA goes in the car with my President Andy
The KL-203 has been fantastic so far though with the 980 and very consistent in boosting whatever I give it.
An easy way to hear your transmit audio for testing microphones, is to listen to yourself with a second radio with no antenna and headphones. I audio check my station when I power up to make sure nothing got bumped or has developed a problem.
