Please excuse me for butting a suggestion in here, as I have not read this entire thread, but the original fault must still be present. (Whatever that is.)got the right parts but r29 cooked again these amps are junk from the start as far as i am concerned
Well it is back working now i am at the bias issue once again
I used the mica ..ever run up on that schematic? thanks3055's are low on gain and different pinout.
Make sure you use the mica insulator under the 179.
Good luck
