Robyn DG-30
ClaimJumper
New Member
Mar 31, 2024
38
18
8
61
Does anybody have or know where I can get a pic of a robin dg30.? Inside near the power Inlet. This was where the power cables came in . 20241101_172305.jpg
This is the lower left corner of the rig. The part I'm interested in.20241101_172939.jpg
This came out of that lower left corner of the PC board. The coil you see in the board and this one went to positive and negative terminals on the jacked up power Inlet housing. I just want to clean it up and put it back to stock. Might have to just run cables through the chassis. Sure would be nice to see what a stock one looks like.
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
