Just got a Robyn T-240D and the plate modulation conversion sounds interesting. Does anyone have any information on this?
I know just enough to be dangerous. lol mainly I am just curious what it does and why it works. Would mini8 be HV or what would be needed? This doesn't look hard to do, what adjustments would be needed after doing this mod?ARE YOU SURE YOU KNOW WHAT YOU ARE DOING!?
This is an AC HV version of the RWOB mod others used...but for Bipolars...
Enclosed in the Final TX strip of that radio so you can see how the bypass works...PLEASE BE CAREFUL and use HV coax cable - it can poke you and destroy tubes...
I wish you the best of luck...
It isn't the best mod for it.
There are no real adjustments after this mod, for all the Modulator does, this mod bypass'es the chokehold they placed in it - and you have to ride the Mic gain to keep the thing from getting too excessive, in both modulation and plate dissipation...
Referring to Grid and Plate issues.
They "choke the mod" down, lower to allow the tube - both Modulator and the Final - to dissipate power for their size inside that box - else you'd need a larger tube and the associated power supply issues...
Note the schematic and the mod itself - they use diodes to keep it "one way" towards the Final tube.
(Man I'm not a tube guy so I can't believe I'm saying this...)
When you broadband it, you're adding more audio -and adding an FM component similar to clipping on a Bipolar, only you're heating up the Final Tube and introducing another path for parasitic problems and one day it may just go SNAP and the tube is toast.
In the Transistor logic view, you're placing Modulation on both the Base and Collector at the same time so what you do is add a compression effect - by Phase modulating the output of the Driver, into the Final - and the Final Tube itself - you hear unfiltered audio resonating with the Carrier the Driver sends to it, along with the Grids resonating with and offsetting, Plate modulation - so you're generating / making the all the grids in the tube work
There's a neon light as modulation peak indicator - if it's on too long or stays on all the time, you have a squeal or oscillation you'll need to track down. Some people back in the day called it their on-air light - I'll let you figure that one out...
The diodes' if they blow, may not blow open - they may blow shorted - think about the sharing of current...
It's just a lot more work on that last stage tube...
New Justin here lol, i was wondering if you could maybe post the full schematic to this unit for me please? Been scouring google all night trying to fid one lol. Basically i was given and saved one of these Robyn240s from the landfill bout a month ago. Im a guitarist, and a music junkie(i live for it lol!) but this thing has a few blown caps inside, pretty sure it was rained on a few times, i see some components caps/resistors i assume have been snipped at some point, oh and it was LOADED to the hilt with friggin stink bugs. So i decided im gonna salvage what components I could use, and idk what Ill do with whats left. This has became a new hobby, ive built a couple simple amplifiers recently. But i digress, i want to take the Transformer, and the tubes out, and im gonna repurpose them into a pre-amp to make my stereo and my main guitar Amplifiers Hybrid Tube/Solid State. So i figured id ask you guys because so far other then a tuning manual that had a piece if schematic, this is the closest ive came to a full schematic lol! Im not new to forums, so i apologize in advance for dredging up an old thread. Buut maybe itll help someone else in the future, and save room on your forum! Thank you in advance if you still have the schematic, either way cheers!Chris/STM: I am with Andy here that rig is screen modulated...yea the Plate mod could make a difference, but you have to add the extra stress you will add to the tubes when doing so.
When you could buy those 6BQ5A's for $.25 each for NOS RCA's or Sylvania's big deal! No longer the case, those and the EL84/6BQ5A (Audio Amps guys) are really in demand and have driven the pricing way up, even the Russian substitutes have risen much in the last few years.(last production dated's are in the mid 60's for RCA/GE/SYL's)
So toss up! I would shop around at a good tube dealer(not some random Ebay'er)
Tube Depot/ Antique radio supply/K5SVC...Electro Harmonics...etc. and buy a couple new ones, plug those in and see what see does. You want the 6BQ5(A) that is the Audio rated tube(IMHO) but good brand GE/ RCA's or Syl's 6BQ5's are good also.
All the Best
Gary
Test the tubes...I have one of these t240's and the receive is out. Where do I begin? It's a friggin spaghetti bowl down there!!!
Screeeech! (Needle ripping across an LP)I am with Andy here that rig is screen modulated...
Sorry!Screeeech! (Needle ripping across an LP)
