Rocket Box 1000XL
Assembled in the US with Chinese parts?
I guess I would like to see what his definition of "built" or "assembled" in the USA means. If the entire amp board is already stamped out in China and all he is doing is mounting it o a heat sink and adding the power and coax line I don't really consider that to be custom built.
Reactions: 390 Wagonmaster
People considering a 12 volt MOSFET amplifier should beware that not a single reputable transistor manufacturer is advertising a 12 volt linear RF MOSFET datasheet in this type of plastic package at power levels this high. Because of that, the ones that are working are almost certainly relabeled switch mode transistors not intended to support bias or linear operation.
All types of tricks are being used to make them function in the linear mode at the expense of reliability and durability. They include adding everything from extra resistors shunting the bias voltage across the gates to using transistors with much higher peak current ratings, hoping that will translate into some ability to sustain AB bias without failure.
That bias also increases the operating gain of a part that struggles to maintain stability due to high inductance and the larger RF currents related to a lower operating voltage producing hundreds of watts. They run hotter than the old bipolar transistors too.
If you understand this ahead of time and don't choose a model that will have to be pushed in order to reach your goal, you'll probably be happy with the cost and performance. Beat it up a little like you could with more rugged transistors and expect disappointment.
Good information.
Just saying...I read that these amps were Chinese made amps, and the guy selling them is the main distributor in the USA.
Hey snippits is this true ? I am talking with a dude in Vegas that claims to be "Rocketbox" I have also made a thread based on the info I have gathered . I believe he designs the boards but outsources ONLY the construction of the board itself with the traces he designed . He then receives them in bulk and builds up his amps on the platform he designed . If you know different please share before I order one of these thing lol .
Honestly even if the boards are made in china if the technology is working the way it should that just saves the consumer money . Its expensive to build circuit boards in bulk but if you can design it on CAD or something and have it delivered I say why not . Its the tech , the components and the knowledge that makes things work for me but Im no genius lol
73's 4-2-zero NJ
Studying the layout of this board has caused me to become a little more skeptical. Missing are any large conductive areas around the transistors and output transformers. The RF currents flowing trough the ground plane of the PC board in this area are high enough to cause heating. The absence of any, adds to oscillation problems and distorted output. While I can't see the back side of the PC board, there do not appear to be enough feed through connections to place a substantial ground plane on that side and it is in use for other traces.
The board is very small, placing all transistors close together. This concentrates heat into a smaller area as it's trying to dissipate though the heatsink. Effort should be made to mount the board on the heatsink so that the row of transistors are not inline with a small number of fins and are laid out perpendicular to the fins for best cooling. Regardless of the size of the board, it should not be mounted to a heatsink that is any smaller than what you would see being used in an old school 10 pill because we actually have more heat to dissipate here.
The area provided to mount the main output combiner, is not large enough for any part that could handle a KW. The suitable part would have to be raised above the board or relocated off to the side of it. The same holds true for the output relay and five output transformers. All being very small for the power level of the board. A quick look at the unloaded board might suggest inverter or AF applications rather than RF, based on layout.
Hello guys sorry for the delay my login was jacked up this is my new Rocket 1000XL we are building the sample kit to make sure this unit performs like it should
Hello and welcome, please keep us updated on the Rocket 1000XL. I am very interested on how this box will perform.
Cheers!
Reactions: 2NC995 and S&W357
Snake oil. Not impressed. Those kind of mosfets will not work properly in this application. I want to see one of these fully tested with a spectrum analyzer, and also see how they perform. I'd also bet they drop power significantly when they get hot from use, too. Not saying the T/S amps are much better (right now), since T/S is still using the junk DEI transistors. But, time will tell, and the proof is in the pudding.
~Cheers~
Welcome to the forum.
As you are just starting this project be aware that there is a lot of RF knowledge here on the forum.
Shockwave and others here have extensive background in design and building RF amps from the ground up.
And you will find that many here are very helpful if/when you run into problems.
Reactions: Eldorado828
What's up Rocket box !! Glad your here to join us finally . I did my best to play middle man with information from you , but I'm glad your here to answer yourself now lol :LOL:
Thanks for hanging in there I told ya I would figure SOMETHING out !
73's WINKDOGG 4-2-ZERO NJ
Ill hit you up on facebook so we can decide on my first "Rocketkit" haha:ROFLMAO:
Lots of cool , smart people here I think you will enjoy it ;) Brian Winks
