Sams PhotoFacts Collection
Dan, I don't suppose you would have the CB-78, Regency CR-142?
EDIT: I see further back that you listed that one as not in your collection. I may have to buy it, if I do, I can pass it on to you.
EDIT AGAIN!: I see that I must have purchased it already from ebay, says it's out for delivery today. Wow, I don't remember doing that lol.
Cable Guy you are right I am missing CB-78 and if you want to pass it on it would be appreciated... Dan
I got the Regency CR-142 scanned from CB-78. If you want, I will scan the others.
Thanks Cable Guy for the info... I know what it takes to scan a section...This is more than enough for now, thank you... Dan
Dan, I hate to have to bother you....
Want to see if you have CB-123. I am looking for the Pearce Simpson Tomcat 23B and it is in that volume.
If you CAN, I would appreciate the whole section!
If that is too much.... schematics, alignment, alignment can location page, and maybe a block diagram if it has that.
Fighting a "good TX but no RCV AUDIO" problem... and I can't find this one.
Thank you sir and wishing you a wonderful New Year and sending my thanks for the job you do here!!!!!
Sorry... I'm missing that one... Dan
  • hygain_3077_pg1_pg20.pdf
  • hygain_3077_pg21_pg31.pdf
  • hygain_3077_pg33_pg43.pdf
Reactions: tecnicoloco
The Hygain 3077 is the first version of the Hygain 7 series (crystal matrix board). Although they're similar, there's 3 of them. The 3107 is the latest 02A PLL version.
RV2 on page 2 of the pg21 - pg43 pdf is the modulation adjustment.
Be sure to make a note of all the screw locations and the 2 shield plates that cover most of the board. You will need to remount the volume and squelch control. A real PITA.
  • Hygain 7 3107 Schematic.pdf
  • Hygain 7 3107 pg21 - pg43.pdf
  • Hygain 7 3107 pg01 - pg20.pdf
Regency formula 23. Im looking for manual and schematic diagram over this radio. Kind regards Thomas Bergman
Here is the section you requested... Dan (Sorry for so many files, my computer is messed up)
  • Regency Formula 23012.pdf
  • Regency Formula 23013.pdf
  • Regency Formula 23014.pdf
  • Regency Formula 23015.pdf
  • Regency Formula 23016.pdf
  • Regency Formula 23017.pdf
  • Regency Formula 23018.pdf
  • Regency Formula 23019.pdf
  • Regency Formula 23020.pdf
  • Regency Formula 23011.pdf
  • Regency Formula 23010.pdf
  • Regency Formula 23001.pdf
  • Regency Formula 23002.pdf
  • Regency Formula 23003.pdf
  • Regency Formula 23004.pdf
  • Regency Formula 23005.pdf
  • Regency Formula 23006.pdf
  • Regency Formula 23007.pdf
  • Regency Formula 23008.pdf
  • Regency Formula 23009.pdf
I'm a schematic/manual hoarder., so I volunteer to turn that into one document. Check back soon, I'll edit post and reupload when done. I will try to put the schematic pages together too.
  • Regency Formula 23 Combined.pdf
    Greg T has left the room.
  • @ Galanary:
