SDR with 10/11 meter antenna
Backwoods40
New Member
Oct 28, 2024
2
Wasn't really sure where this should go, but figure the hams would best be able to answer.
I recently got an SDR, installed the software, and since a 10/11 meter antenna is all I have at the moment, decided to connect that to see what I can receive.
The antenna is a half wave & can be tuned for 25 to 30MHz, but I was surprised to find that I'm easily able to Rx the local FM radio stations, air traffic, NOAA, and tons of short wave stations from around the world.
The SDR is Rx only from 500KHz to 1.75GHz and I haven't had the time yet to scan all bands.
My question is, since this is Rx only, is this antenna all I need? Will I be missing anything without using a discone?
For receive, it will probably work at least as well or better than a discone at frequencies of 30 MHz or less. Above that the discone will work better.
Keep in mind that the discone is a compromise antenna as well, considering it is so broad-banded. You are always better with a dedicated antenna for each band, but unless you have acreage to put up an antenna farm there will always be compromises nescessary!
Reactions: Backwoods40
and more detail here
In any case your first line of defense is an antenna resonant at the desired frequency. The next step is impedance matching. Finally a band pass filter or switchable network (preselector.)
Analog HF preselector simple
Analog HF preselector not so simple
Analog HF preselector explained
Yet another
'bout covers it ;-)
I'd skip the discone because I don't use one and have had great enjoyment with my RTL-SDR's. Anything outside and does the job is great for me. Of course maybe I'm missing some stuff. If I could guess what I'm missing, I could just fashion an antenna for that band and not have an antenna that will poke me in the eye. Of course I'll probably start thinking I want a discone now. Thanks Brother !!! :-(
I've tried the preamps and stuff and I get easier good performance just with the SDR hooked to an outdoor antenna.
  • @ W4KVW:
  • @ W4KVW:
