Wavrider,
remember that even though you choke off those CMC's from the coax by using a coax choke; they will still radiate down your metal mast if you dont isolate your antenna from it.
not saying you dont already know this, just that many people dont consider it.
think about it; why wouldnt they flow right down that metal mast?
LC, check this Website out.
AA5TB - The End Fed Half Wave Antenna
AA5tb did some work on a related issue regarding how an end fed 1/2 wave with a 1/4 wave matcher really works. I think it is similar to the A99. He tested and evaluated what is necessary to provide a return path, the actual Ground Plane needed for such an antenna to work. Something to consider at least.
Actually I think he claims the end fed 1/2 wave radiator needs only a very small length counterpoise, in the area of .05 wavelength wire connected to the ground side of the matcher to make the opposite pole. He notes that this will allow for a full functioning CMC return path to make the EFHW work. For years we have heard stories about how the A99 uses the feed line as a counterpoise or GP and in part that is true---and it may be a lot shorter that we think if AA5tb is right. The question then is---what part of the feed line?
I was curious and thought after reading his articles on EFHW's, what could I do that might support his idea. He had done a lot of work and he shows how in detail right there in the article. He may even have a video on this work. Anybody with better skills than me might be able to check him out, so I thought---maybe he's on to something.
I asked myself, what if I remove the feed line and tested the antenna's feed point, and what if AA5tb
was not right and the A99 in fact needed the feed line as a ground plane, would I see some issues with the match. Well, I hooked my Autek VA1 directly to the feed point and instead of a bad tune, I saw virtually the same numbers compared to using a 14'5" foot length of RG8x, a tuned jumper cut to 27.205.
How does this relate to our issues with CMC's and the need for a balun. What we hope happens with a choke is to create
high impedance point at the feed point in order to help stop CMC from flowing down the feed line and the mast. In order for this to be effective, we also need a conductor (a ground plane) to redirect these currents back into the feed point and keep all the RF flowing in the antenna and not on the feed line or mast. If we don't, I understand that CMC's will just flow right on past the choke whether the mast is insulated or not.
I did some work with my A99 this past summer. I insulated it from the mast by placing some PVC in the mounting hardware.
I got some mixed results, but my strongest Signal Reports were with the A99 insulated without a GPK. I did not raise the antenna above the mast with the insulator and that may account for a difference. Reports from Bob85 and Multimode200 note nice increases in signals when insulated with a ground plane kit. I don't think either one used a choke however.
I forget who started this thread. I hope I didn't get off track.
