Any two antennas 'near' each other, especially if designed for the same band will affect each other. You can't get around that. One of the ways they can affect each other is the apparent SWR of either/both antennas can change. Another is that the resonant frequency of both can also change. This affect lessens as the design frequency of the two antennas diverge. The further the frequencies are from each other the less affect each will have on the other. If both antennas are for the same -band- then count on there being some affects. The same for proximity, how close they are together. The closer the worser, sort of. That TV antenna may not affect the vertical (or the dipole) much but you can bet that there's some affect. Getting rid of that 'affect', or minimizing it is part of the tuning procedure for any antenna. But that 'tuning' can only go so far, the affect of one antenna on another can only be compensated for so much, it can never be eliminated completely except by distance.
