I know a guy who brought some ground inside. 5 gallon bucket full of dirt with a so239 on the lid.
Guess I have been lucky!...At least 2 direct Hits at this location, did not loose any equipment.you get directly hit with lightning it wont matter if its grounded or not, its gonna f**k s**t up.
Lightning hits the power lines its not gonna choose the ground only, its gonna go everywhere, hot, neutral, cable, phone.
Its game over
Good point,Man what a mess all of that oil will make with the direct strike. Maybe even a fire with it be petroleum based ?
SIX-SHOOTER
There are more to lighting strikes than 90% of the masses understand.
Generally some people seem to believe Lighting originates only from above.
Wrong! When it occurs some of the most powerful strikes originate from the Earth UP, known as Ground to Cloud Lighting!
These generally originate from Skyscrapers, Tall TV and Communication towers, however not always true.
Have you ever seen a tree that is split from top all the way to dirt level? Good chance that was Ground to Cloud, the strike originated from under ground and traveled UP the tree to air.
Another example: think a strike was really close when the Flash and Bang were so close together you did not even have time to blink?
Good chance that was Ground to Cloud.
Your poorly or ungrounded tower or mast can build this same charge. I have seen the rebar under a driveway or slab home exploded up thru the concrete. Extreme situations, yes of course; but does occur.
Many Myth's surround lighting:
Good reading here, but even with proof most still don't believe!
http://stormhighway.com/weather_myths.php
http://www.ztresearch.com/
http://stormhighway.com/tower.php#2
All the Best
Gary
I think you're confusing "lighting" with "lightning" (notice the extra "n" in "lightNing"?
Consider this, just unplugging isn't fool proof either espcially if your antenna is attached to or mounted real close to your house. The proximity alone can be catastrophic. Some of the other posts here give good examples of what can still happen even if unplugged.Forget the ground rods, forget the poly phasers, and when your house catches on fire because you forgot to un plug..... you can forget your fire insurance paying out. Lightning is only part of the reason to ground your station.
PS: Homeowner's Insurance normally has clauses that if "they" believe system not done to Proper Codes and practices, I have seen claims rejected!
For what it's worth. A customer of mine had a direct lighting strike, it hit a chain link fence around a central plant. It was determined the voltage went down from the properly grounded fence then UP from the ground and blew the MCC to snot.
