I hope Fedex will pay for that tube without a hassle. If not, you could always make a LED modulation indicator or a table lamp out of it. Using a glass cutter, the plate cap on top is your pivot point needed to score a perfect circle. The circle needs to be large enough to remove all the guts. If you managed not to shatter the glass, the top can be glued back on afterwards. Use your imagination or any number to decorative LED configurations that are sold. Solder the LED leads to a couple of pins on the bottom. Drill holes in a nice thick piece of wood for the pins to fit into and to channel a pair of wires away from the base.
That’s a shame, I’m not hip to tubes but it looks pretty damn cool.
Also I like Sunbulls idea, that would probably look really cool, way cool.
It reminds me of this guy, haha :
And that made me sad, they broke GUNTER.
