Well, an opinion is what yo got from me.
I don't see a high voltage node at the top of the cone on you model(the one you sent me), but as I've clearly said, I am handicapped with not knowing the modeling program. Where I do see it is on the vertical.
Of course, something are different with this cone set up than with a coax, it is attached to the bottom of the vertical radiator, so current on the cone could be supplied from there and not from the top if a high voltage condition is present at the ring.
SW is also saying, it seems, that the cone adds its value to the TOA by
preventing the lower 1/4 wave of the antenna from driving the 40° lobe making it possible for the higher gain of the longer antenna to direct toward the horizon.
Now I see a part of dilemma, can we have it both ways or not?
1. Does the bottom cone radiate at all, or sufficiently enough to add gain? or
2. is it simply shielding the negative aspects of the lower 1/4ƛ that drive the 40° secondary so high?
Because you seem to lack evidence of the 1st, the second seems to have greater plausibility, so you want to see some evidence of what is actually going on within the data. Fair enough.
I have not intended to not answer any questions. Some I can not answer. Others I have to the best of my ability.
As for what I think I see in the CST graphic I answered fully. I admitted I don't have any way of knowing what is going on with the graphic except what I trust SW has said of it, and that if I have understood the EZnec model based on what has been explained to me regarding it, then I saw the what appears to be the same demonstrated in the CST model except in a more graphic way.
Trusting any of the models has to go back to two things:
1. that the one modeling with the program has used it competently, and
2. that the maker (programmer) of the software managed to build in the sufficiency of attributes to capture fully the workings of the antenna.
Like you, I am waiting for the outcome of the second question that has arrisen throughout all the discussions of this antenna.
One thing I would like clarification on, not due to your lack of already supplying it, but to my tendency to lose focus of one point or the other in the complexity of this discussion.
Can you once again demonstrate the problem you have expressed right here?
I did that already, and I referred to raising the radials upward as pressing down on the high angled lobe. However on finishing the Vector model, I now see that adding the length to the radials on this Vector seems to cause this idea to fail. Additionally this model shows the radials out of phase with the radiator. SW, this revelation is all new to me.
I know this is prominent part of this thread, yet I am not following it clearly, more than likely due to my work/sleep pattern currently providing gaps in the flow for me, which results in a start and stop kind of thinking.
As for this:
. So, is picking a side to agree or disagree, factual? I say at the very least we have to try and keep an open mind if it matters.
It is why I am following the thread.
When it comes to using an antennaa, I figure build it and fly it, or buy and fly, and if it works for you, be happy. Understanding an antenna is another stoy, and that is why I bother to read these threads.
Another point you make that my experiences have convinced me of:
I believe the only advantage that the 5/8 wave has over the end fed ½ wave is the slight height advantage noted if the antennas are compared at the same feed point height. There is also a height advantage for the maximum TOA that might be noted with the 5/8 wave at some particular heights. Otherwise, I see about the same results from both styled antennas if the height advantage is mitigated out of the comparison.
I recently did a model test of this idea using several different length vertical antennas that showed a nice advantage for the longer radiators, but when I laid all the antennas down horizontal, taking away the height advantage, all the antennas produced gain and angle figures very similar. It was almost unbelievable.
Arguments have yet to convince me otherwise where omnis are concerned. It isn't a popular viewpoint. Why bother with a longer antenna? Because folks are most often limited in the height they can get the bottom of an antenna, so it matters.
What I will likely pursue is an understanding of what height actually maximizes which antenna, or maybe I'll just lay them all on their sides
