Hello Marconi:
Marconi Said:
"Jay, you have seen this antenna first hand, right? Would you agree that this tuner, the hot side only for now, is about a 1/4 wave long and that it hooks directly to the loop at one of the corners, a fiberglass support, and that this wire loop is ruffly a full wavelength long without an insulator, and that it is a continuous loop? I'm not talking about the shrink wrap insulating material that is located at each support corner either.
When you helped build the one you mentioned, did you use and analyzer? Was it responsive with adjustments to the tuner or was it like Dawginfi said, "...It wouldn't tune with a MfJ analyzer."
The SE 4 Element Quad Beam Antenna was feed the same way the Avanti PDLII 2 Element Quad Antenna was feed, as far as the connection to the quad loop wire, is concerned. (The PDLII used Gamma Matchs, which can only match to a lower than the coax impedance) The SE Quad Antenna used what looked like a 1/4 wavelength type of pickup matching circuit.
The SE 4 element quad had two points on the driven element loop that where feed, again just like the PDLII Quad Beam Antenna. That is the feeding wires where attached at the bottom and one to the side of the driven quad element. Then these feeding or connection wires where brought down to the Boom, and mounted on a Plastic Insulator, and routed towards the forward end of the beam towards the first director. These two wires are routed thru another Plastic Stand-off and bent back toward the driven element, and connected to a Brass type rod.
The center wire of each coax is connected to the separate brass type rod, and the shield of the coaxes is connected by a clamp to the Boom.
Maybe I need to post a simplified drawing for you.
Yes I used a MFJ259B Antenna Analyzer, and another analyzer, and they both measured the same SWR. We had to adjust the connection point on the brass type rod to lower the SWR, but didn't see a lower SWR as the instructions had shown.
Thas why I wanted to know if we where doing something wrong and would love to hear how to adjust the SE 4 element beam. Again thats why I wanted to call the guys at SE for help.
Would like to hear from anyone if they have a fix or suggestion.
Jay in the Mojave
www.a1antennas.com <img src=http://www.wwdx.org/smilies/posticon44.gif ALT=":44">
</p>
