I just got a hell of a deal on an old Fluke 6060A/AN. The guy still has some listed, although it appears that all of them have error codes showing. Mine did as well. He has them listed for $95 or make offer. I offered $70, which made it about $120 after shipping.
When I got it, I started out by testing the voltage rails. +15V was being pulled down, so I started disconnecting harnesses until the voltage came up. I followed the harness and started pulling boards until I got voltage again, and tracked it down to the communication board, which isn't necessary for opertation. I removed it, and it worked perfectly. Since there were only ICs on the communication board, I thought that I might be able to repair it and get rid of the ADDR light on the display, so I plugged it back in to see if I could feel something getting hot. When I plugged it back in though, the ADDR light went away, and it passed the self tests. The board was just not inserted properly. The only part I had to replace was a tantalum I blew when I slipped with my probe.
If you are interested, and aren't afraid of doing some troubleshooting, that's a pretty good signal generator for $120 shipped, and he still has a few left. His store is at
http://www.ebaystores.com/Express-Equipment-Auctions
Keep in mind, the error codes are not the same as mine had, so it is likely not the same problem on those other units.
