Its only CB guys, not rocket science or NVLAP accredited sanctions here (that was last month here at the shop). The Bird wattmeter is fine for lay measurements. If you are really that concerned about your power measurements send it off to an accredited lab with NIST traceability.
[/sarcasm off]
Fact of the matter is that most companies (Vectronics, Para Dynamics, Palstar, MFJ, et al.) use the Bird Thruline for their calibration bench. [Well at least that was the case when I was working for them].
Geekster edited [added info]
From the Bird 43 Manual:
Attenuation (power lost by heat in a line) as well as VSWR may be measured by inserting the unknown line between two Thruline wattmeters, or between a Thruline wattmeter and a Termaline absorption wattmeter.
I have never tried this with the Birds but have performed a similar test when calculating ERP for a coordinated repeater (OARC).
[/sarcasm off]
