Sirio 2016
Yes the 2016 has the black plastic connectors with the little screws to hold the joints together.
Well, the best thing to do is use Scotchbright to clean the joints, put them together bone dry, spray them with clear enamel or urethane, quickly install the plastic seals, spray them again, use a piece of shrink tube 2" longer on either end, and then spray them again. You'll never have to touch them again. Takes a little longer, but I did this many many years ago to a Ringo I had. when I took it down it was perfect. Also did it on an original Star Duster that was up for a couple of decades. Never an issue.
Reactions: Rwb
yes our 2008's have black plastic n screws
Doesn't the 2016 come with those black plastic connectors that join and seal the joints? My 2008 did. Then I sprayed them with clear enamel, used shrink tube, and sprayed them again.
  • @ W4KVW:
    6m open
    Bunches of TX+ LA / OK / MS /CO /AL / NM AND OTHERS...good sigs...op in MS on squalo was over S9 :cool: (y)
    Texas and Lousiana very strong here....
