Undertaker, just so you know, these antennas are real broad branded and you are setting it for 27.000mhz which is the low end of the CB band. For a more center of the CB band setting you want to make the tip height @ 40.55" or 1030mm which is about center of the CB band depending on who you ask. I go by channel 20, some go by channel 19. Either way, it's not that much difference. At channel 19 it's 41.73" or 1060mm. This should give enough banwitdth to cover the CB band for sure. It's pretty much a set it and forget it antenna. Not much to them. Make sure the radials are measured correctly and use blue LOCTITE on all the Allen head screws. Also no-ox on all the joints and the screws that hold the joints together. And also make sure to weather proof the connector well!! And any other area where it appears water might get in. Place it up at least to 30ft or more and it will work well. The higher the better. JMHO.
