i have just bought a solacon a99 and i cant get the SWR down below 2 .. the antenna is not close to anything and is mounted on a 10ft alloy pole .. ive tested the coax end to end for continuity and that checks out when i plug the coax back in to the antenna it gives me a dead short the two parts of the coax wire seem to be touching is this correct ?? and plus when i ( TX ) on my radio i get a very bad loud buzzing i have moved the psu and this happens with any psu i use and with any radio im no expert but any help please thank you mark
Many vertical antennas will show a dead short if you use a DC meter to test it. But at RF freqs - which is AC and not DC - it sees the antenna differently than DC does. IOW - that is normal and should be expected. No foul.
These antennas benefit with a ground plane kit. They will work fine w/o it. You say you have it on a 10 ft pole. Fine. How high up is it and what do you consider 'close' to any object?
Best results are had with the antenna as high as you can get it with a ground plane kit and at least 20-30 ft away/above from any metal object.
Owned and used two of these antennas and never had a problem with either of them.
Your power supply is wigging out because of RF feedback from the antenna. Make sure the supply is properly grounded and get it as far away from your antenna as you can. IOW - move the antenna farther away and up.
You probably are already aware that there are tuning rings on the A99. Sure you adjusted them right?
There are copy-cat antennas of this antenna model and not very well made at that. Hope yours is genuine.
Most people just put these things up right out of the box and don't need to tune it, as they come pre-tuned.
Did you test the SWR on ch 1, 20, & 40?
What were the results?
Did you re-calibrate the SWR meter each time you tested on each of these channels?
