That'll work, you'll just have to feed it quickly.
Yep...I will try to find a pro to do it...if I cannot....then I will give it my best shot.
Anyone ever tried this guys way of installing a pl-259?
Prolly more of a chance of corrosion creating a bad ground that way?
When I have made my own coax cables, I use a little urethane glue or silicon adhesive right where the coax enters the PL connector. The urethane glue is not only waterproof, but offers a small measure of strain relief to the coax itself.
If you are concerned about water intrusion into the PL connection at the antenna, there is a special sealant tape available that is weather resistant that I use on all of my antennas. I call it 'goop tape'; don't recall its trade name. Sorry.
This will do you fine for PL-259s:
Soldering Irons by WELLER - Soldering Tools by Zoro Tools Industrial Supplies
It's quite a bit larger than what you likely need for circuit board work, but this (or an American Beauty 100 watt iron) fills the requirement for a MASSIVE tip, compared to the connector body.
