What mic are you using? Do you have another one to try?I have fs23 and I can't get no modulation just a dead key I replaced all audio tubes everything else seem fine dead key no modulation please help
Replacing the relay is a very good idea. Funny things happened to sonar and I'm assuming other tube transceivers when there is a relay problem. Make sure that you clean the the relay input sockets.Know where I can get a replacement set of crystals?
I see most of the tubes in this radio are available on ebay.
I ordered a replacement relay already.
Can someone tell me (with this particular radio in mind) the best way to discharge all the lethal HV inside before working on it? I have no previous experience with tube radios that store a charge and I want to be as safe as possible.
Are the 3 big capacitors in the radio the only thing I'm worried about discharging before safely touching/replacing parts (relay, tubes, crystals, etc.)
Awesome!I get mine tommrow two of them .I'm stoked. Hope they are complete.
