It's a Maco antenna - never had a PDL ll.airplane1 said:DXman,
What antenna is on the tower in your pics? I thought I seen a pic before you had on here with a pdl-2 on tower.
also does the parkerized paint affect you swr and does it stick good to aluminum and will it be ok for pdl-2 plastic hubs or is there a uv block paint I could use on the plastic hubs?AP
Master Chief said:I forgot to add, according to Solarcon, painting the A-99 will give you 14.5db gain!!!
"...I shot an arrow in the air..."
Wouldn't it be easier to draw one up into those "telephone pole" forest of trees?
Just use the mast pipe as a counterweigt
102
that 102" whip was camoed good till they found the coax then i was shut down i hate apartments
