Base SPT500 Radials
Van Lifeson
Well-Known Member
Aug 11, 2018
219
249
53
58
do the radials radiate on a super penetrator?
Trying to figure out the operation with the shorting rod connecting to the radio plate and the bottom of the antenna. thanks!
in a word ....no.... although there is some minor "phase difference" type radiation from the radials , it is a calculated value only and you won't be able to see it without sophisticated far field measuring equipment.
The radials provide a low loss return path.
  • @ Galanary:
