SR-955HPC capacitor C54 identification? SMD
Crambone
Well-Known Member
Jan 22, 2019
509
160
53
56
Guys I found C54 on my radio is NO GOOD and I'm not familiar with SMD type. I see on the schematic its a 103P. I'm just not sure what to order from Mouser or Digi Key? I believe it's a .01uf 10V 0% but not sure on size or if I even looked that up correct?
Crambone
103 capac
It's 10nF, not 100nF
103 mean 10 000 pF
I was going by this:
A capacitor code of 103 can indicate different values depending on the type of capacitor:
  • Ceramic disc capacitor
    A ceramic disc capacitor with a code of 103 has a capacitance of 10,000 pico Farads (pF). The first two digits of the code, 10, indicate the first part of the value, and the third digit indicates the number of extra zeros. In this case, there are three extra zeros, so the value is 10,000.
  • Surface-mount capacitor
    A surface-mount capacitor with a code of 103 is equal to 0.01 microFarads (uF). This is calculated as 10 * 10^3pF = 10 nanoFarads (nF) = 0.01uF.
103 capac
.01uF tolerance is P=+100%. Anything between .01uF and .02uF will work.
  • @ kopcicle:
    535A has left the room.
  • @ AmericanEagle575:
