SSTV on VHF
Sonwatcher
3,413
25
48
Colorado
Has anyone tried this on VHF ? It seems if you use MMSSTV software an HT would be the simplest way to do this with a computer for PTT function when sending an image. Otherwise you can send via your computer speaker while keying your mic. The following web page describes using an HTX-202 for SSTV.
http://www.qsl.net/ka8vit/sstv/sstv.htm
Sonwatcher,
SSTV is as practical on VHF as it is on HF, just a different radio. FM tends to produce a 'better' picture than SSB does, just not as much interference/static etc.
Without a hard wired connection between PC and radio the picture quality goes down. The radio's mic picks up all the 'other' stuff it hears along with the sound from the speakers, sort of how sensitive the mic is, you know? But, it will work.
And, depending on the computer, PCs tend to be a bit more susceptible to RFI, the computer's speed is much closer to VHF than HF so something else to think about.
Isolation transformers and blocking capacitors in the 'data' and audio line help. (So does a 5 gallon bucket of torroids!) The keying circuits from the serial ports are NOT that difficult to build, or, just get one of the interfaces ('Rigblaster', etc.).
SSTV is fun. Especially if you like playing with graphics programs and so on. [Warning: Any pictures of yourself WILL be used against you! And that's half the fun of the whole thing.]
SSTV programs... The biggy now seems to be MMSSTV. That's cuz it's free. There are other, and better programs around (that 'better' depends on which you like the best). Those are 'analog' programs, there are also a couple of (real) 'digital' programs around such as 'HamPal'. They use error correcting procedures so a 'perfect' picture is more likely than the 'alalog' programs (also takes longer to send/receiver, requires more 'work' on your part).
Anyway, give it a shot. What's another 'addiction' or two, right?
Thanks Doc. I listen to it quite a bit on HF. I just haven't heard anyone use it on VHF. I have an HTX-202 to work off of so I think it would be fun. I have MMSSTV and hook my HF radio directly to the computer with an isolation transformer.
sstv
It wrks just the same on hf and vhf, problem on hf you usually can find someone, vhf you have to search or find someone in your area to try it. look under 2 meter sstv nets on the web you might have some luck, if you were closer I would try it but to far.
DOCTOR/795
DOCTOR/795
If I could get my ftm350 to sync with hrd but its not supported nor can I find a program to do sstv via my radio.
Sent from my DROIDX using Tapatalk 2
I would suggest MMSSTV as a substitute for HRD for SSTV. It would require the same connections as HRD does (I think), or an input/output to the sound card. No idea how your radio handles PTT functions though. I know I've used the same interface for SSTV and an older version of HRD (can't get the new version to run at all) on Kenwood radios though.
MMSSTV offers more graphic functions than HRD does so it's just more practical. Any program that does SSTV takes some adjusting and learning on the user's part. Since SSTV isn't very common on VHF, getting your feet wet on HF is just a lot easier. Once you figure out how to do the calibrating on HF, it should be a 'snap' on VHF without much problem at all. Basically, there's just more help on HF than you'll find on VHF, lots more users on HF to get help from.
If you enjoy messing with graphics or pictures, SSTV is very addictive. You've been warned!
Thanks.
A LOCA CLUB DOES SSTV WEDNESDAY NIGHTS.
Sent from my Xoom using Tapatalk 2
Local club? You've got it made! There's boud to be at least one who will tell you more than you ever wanted to know about how to go about and set up your radio, computer and software for SSTV.
One 'nice' thing about it is that the interface used for SSTV will work for any computer/radio mode, not just SSTV.
At one time, there was a fair amount of TV activity - both fast and slow-scan - in the Akron/NEOH region. We also organized 10/6/2M RTTY and keyboard-keyboard packet nets.
Trick is getting everyone to play, and getting the required gear into their hands. It's a lot easier with soundcard-based setups than it is with, say, a Robot 400 or a Model 28ASR/ST6000.
Is there a configure on MMSSTV to control the radio for rx signals/pictures ? Instead of ptt the mic over a speaker.
yes,.... go: OPTION..... setupMMSSTV..... TX then select your com port
Sweet ! After lunch ill head home and check it out. My arrl bandplan chart doesnt specify where to operate digital modes....u have a quick link to the allocated spots ?
