Get a frequency counter. See where it is transmitting.I have a 148gtl recently i aligned it is putting out wattage and modulation on my watt meter but has zero carrier cannot hear it on my test radio as well .
Good call. I chased my tail for a few days until the light bulb went off in my head. I'm never w/o one now.Get a frequency counter. See where it is transmitting.
It sounds like it is now transmitting somewhere other than the CB band. When you say you aligned it, did you use a proper frequency counter, VTVM, scope, etc. ?I have a 148gtl recently i aligned it is putting out wattage and modulation on my watt meter but has zero carrier cannot hear it on my test radio as well .
This tells us you need bigger guns than what you're pointing at it now. Do you know if the radio receives the channel number on the display?cannot hear it on my test radio as well .
Then either it is blown up, not seeing RF or out of range.i do have a frequency counter displays absoulletely nothing
If the freq counter doesn't help, next thing to check with would be a spectrum analyzer.Then either it is blown up, not seeing RF or out of range.
But you said the radio has wattage and modulation ! If the radio has wattage and modulation it is obviously radiating a signal somewhere, so the frequency counter should be reading something ......... Might be time for a better counter maybe ?i do have a frequency counter displays absoulletely nothing
A wattmeter reading and a counter that ignores it tells us that there is a whole list of broken stuff here, maybe? A broken counter that someone fried with his linear will probably read zero. Forty years ago when inline counters were popular, lightning was the big risk, leaving them in line during a storm.If the radio has wattage and modulation it is obviously radiating a signal somewhere, so the frequency counter should be reading something
