Hi Guys, I also find RX on SSB Stryker Poor.. Has anyone tried to modify the AGC..?Well here is the agc circuit that Shawn sent me from Stryker if anyone wants to play with it? I am not sure if the timing will help with the overload though. But there it is
Hi did anyone find a fix...!never heard of that problem? really??. ssb sounds so bad on the 955 I sent mine back 2 times then the 3rd time they sent a new radio and it had the same issue on ssb receive
Hi any luck with Stryker 955..?Well here is the agc circuit that Shawn sent me from Stryker if anyone wants to play with it? I am not sure if the timing will help with the overload though. But there it is
Just get receive a aligned it’ll make a big differenceHi Guys, I also find RX on SSB Stryker Poor.. Has anyone tried to modify the AGC..?
Cheers
Yeah, that's the key. If you can back off RF gain, and then use the filter it will quiet down, but the 955 is noisy on receive. Even doing this it still won't stop the noise, but it does make it more pleasant to listen to.just back off the rf gain a little you could squelch out the noise works for me
