Yup same as a Wilson screw mount to mag , trucker style is different isn't it ? Not sure w/out checking isn't the load part way up the antenna ? I'll check later this pc sucks !
Yup same as a Wilson screw mount to mag , ....
imo i always felt the same way. ive never expermented with this though. only reason im looking into enclosed coil is up here in n.w pa we get alot of freezing rain /snow.Yes the trucker style has the shaft. My knowledge is the longer the shaft, the longer the loaded section and that means better performance. I’ll say that’s an opinionated subject or statement maybe. I know raising the coil over the highest point of the vehicle definitely helps in several areas.
I’m trying to get in on that first batch of M1’s so I’m gonna call Stryker today and while I’m on the phone with them, see if that trucker lights up too.
Well we get a little bit but not a lot and I’ve ran a Predator for a loooong time. Never had an issue with it but I certainly understand the concern for the closed coil.imo i always felt the same way. ive never expermented with this though. only reason im looking into enclosed coil is up here in n.w pa we get alot of freezing rain /snow.
just curious as to where ya mounted it? my current antenna is a sirio 5000 fighter series .on my mfj 259b x= 0 is at 26xxx.guess i need to trim whip.can i trim it from the top its much thinner...lol. wilsons quaility has suffered some BUT they still tx/rx just as good and im sure they still handle power. for what its worth my wilson 5000 x=0 for most of the 11 meter bandThe 17" shaft predator was the shortest that would tune well on my truck. With the shorter shafts the viswars would go up with the leenyar on.
Are the wilson 1000 and 5000 mag mounts still decent? I've been thinking about getting one for the company truck when I have to go out of town.
on my s10 its a extended cab i mount mine very close to the third brake light .i got a sunroof in the center.It was on a puck mount as far back as possible on an extended cab pick-up. About 6 inches in front of the 3rd brake light.
Well I’m not the authority on antennas but I’ll relay what the wholesalers are telling me, you be the judge..
With the tariff tax thing, Wilson is going up and in my opinion, they’re already high enough. On top of that, I’ve been told they aren’t owned by Wilson but Barjan now. I guess if that’s true then quality could go either way.
And for those two reasons, I’ve been pushing Stryker antennas. My personal choice is Predator and where they’ll work, I push that.
