I hear more and more people love this radio on am and ssb. clear and loun audio. do they drift and can you but one new in the box and easily convert it yourself. or does it need a complete tune up and conversion. Thank you!
I've heard they are a good radio as long as someone is not trying to squeeze every watt they can it out of them. They are rock solid on SSB, and do well on AM as well. But for the money you can just about get an HF radio.
Also. No way would I run one off a cigarette lighter plug. They draw too many amps!! You need a good power supply to run these radios. Something with at least 15-20 amps minimum. Even a battery isn't going to hack it. You need a good power supply and a good antenna system as well. The radio from all the reviews I have read is a good radio. To me they are a bit over priced. Like I said, for not much more you can get a damn good used HF radio or even a basic new one. Which on SSB will do a better job IMO. But I'm sure there will be others that disagree. Also having a good tech to tune and align the radio is a must. No golden screwdriver type ones! There is a lot of info about this rsdio floating around the forum here. Just have to look for it. Hope this helps. And have a good one.
Sounds as if you went the HF radio route. Am I correct?? They just do so much better on SSB and if setup right can be made to do well on AM. That or you got a radio without all the bells and whistles. I am the same way. I almost bought one, but went the HFradio route, winning a kenwood ts140s for about $300 shipped and also getting an Icom 746 fresh back from Icom services and all bugs worked out. I now use the Icom as my main base radio. It all depends on what you are looking for I suppose. Your thoughts jon666??
Love my FT 450 D!i have 2 ham radios a kenwood ts2000
and a yaesu ft 450d
i would like to set one up as a portable, 110v power supply, cig lighter plug and maybe a battery,
hope someone here replies with a review, JUNK or NOT ?
