Suggestions for 6 meter Antenna
The thing about 6 meters, when it is open you can stick a coat hangar in the SO-239 port and work DX. But it is not open all the time.
The Moxon described above is easy to make. I velcroed one to the top of my pick up shell. Not an exact fit but it worked good enough to make a lot of DX contacts.
If you got basic hand tools make a beam. I built the one in the link below. Works like a champ. I've since used the gamma match design and built a 6 ele for the base, and a 4 ele for rover. I used element lengths and spacing from another website. If I can find it I'll post it too.
And if you want to go digital, 6 meters is open ever week end with all the ping jockeys. I get tired of talking about the weather.
http://members.aol.com/n2kbk/6m.html
http://www.ve3sqb.com/
Moleculo said:
Skeeterman, Happy_Hamer builds a nice little 6 meter horizontal loop that would also work pretty well. Nothing like supporting a forum member ;)
Hammer, You have PM
  • @ Geoexplorer69:
  • @ Geoexplorer69:
